EricDesilets
I know low points in fire sprinkler systems need to have a way to evacuate the water that is trapped.
However, the only argument I found to justify this requirement is the corrosion that can be caused in that low point.
So, I'm wondering if the same requirement should apply with CPVC piping?
Since there's no corrosion expected in this piping, does an auxiliary drain is still mandatory?
Thanks for your help!
