We try to use low pressure injection molding to produce small current sensors (including sensitive windings). The parts have a hinge to make it openable. Using Overtec 5FR, we have quality issues, especially for the hinge. The material is very soft, so we can make the hinge as thick as 4mm, but after a few hundreds openings, it starts crack where the material elongates most - we fear it is even worse at lower temperature.
Does anyone have experience to share with the Overtec 5FR, or would advise an alternative material (we inject at 200Celsius, around 5bars - manually, with a hotmelt-glue-like gun.)
Thks, Pierre
Thks, Pierre
