CuriousElectron
- Jun 24, 2017
- 187
Greetings,
Is it a common practice to use a lower ratio CT if the Instantaneous tap(setting) is enabled on a protective relay? In this scenario since it is expected for the relay to pick up on the fault current without any delay and trip the breaker within 5-6 cycles. If coordination and time delay is required, then CT saturation is taken into account and a higher ratio CT along with appropriate voltage class rating of the CT is selected.
Thoughts?
EE
Thoughts?
EE
