EngTipper.
- Sep 21, 2022
- 10
I have a simply support wide flange beam supporting a slab. The beam needs rotational restraint at the supports as usual, which in this case is at wall plates into a column. However, due to an existing concrete capital a double angle connection into a wall plate will take up less than half of the beam depth, so I'm assuming this wall plate connection no longer provides rotational restraint. I will therefore provide a lateral brace at the top (compression) flange into the slab, which will act as my LTB restraint.
Are there any other issues with regards to lateral restraint of this beam I should be considering? My understanding is that I don't need any specific type of restraint at this wall plate connection because I'm bracing the top flange.
