Guys
As you state that the voltage is 415V, I assume you are therefore referring to a UK system, this would therefore come under the IEE Regulations (BS 7671) not the NEC, NEMA or IEEE43 (not that there is anything wrong with those standards - they just dont generally apply in the UK).
BS 7671 Reg 713-4, Table 71A Applies
For an LV (415V) system, the DC test voltage should be 500V and the minimum resistance should be 0.5 Megohm, in practice is is unlikely that the actual reading should be anywhere as near as low as this anyway unless you have an old cable.
Above 500V, the DC test voltage required is 1000V and the minimum acceptable reading would be 1 Megohm.
Hope this helps.
_______________________________________
Regards -
Colin J Flatters
Consulting Engineer & Project Manager
