JBUDA54
- Aug 7, 2001
- 110
Hello All,
I am on a project that has a 200HP Chipper Discharge Screw Conveyor that needs to be controlled from a VFD. I have research that the cutoff from LV to MV VFD HP is 500HP. ie below 500HP LV VFD and above 500HP MV VFD due to the economics. Most of these papers were written in the 90s. Are they any recent studies that have this type of data?
I have searched this site and goolged that info and can not find recent studies. I am trying to build a case that we need to use a 460V VFD vs a 2300V VFD. The cost of the motor and drive in the LV case will be cheaper but the cabling and installation cost will be more. With the price of copper going up I suspect that the 500HP cut off is changing to a lower HP rating.
But is 200HP a candidate for 2300V VFD control?
TIA Jbuda54
TIA Jbuda54
