StructuralHokie03
- Dec 17, 2013
- 3
Has anyone ever specified or constructed an LVL flitch beam utilizing a WT shape with the flange on the bottom and 2 LVL's on each side? Is there any reason to avoid such madness?
Here is the situation. I have to provide a flush beam within an 11 7/8" "I" joist floor system. The beam spans approximately 21'-6", supports second floor joists flush framing into each side as well as a wall above that supports attic floor joists. I've run the analysis and I can get a traditional flitch beam to work using three (3) 11 7/8" LVL's with two (2) 1/2" x 11 3/4" steel plates. That equals approximately 40 plf of steel.
I then started looking at other alternatives, steel beams, channels, etc. I decided to look at a WT 12 x 31 installed with the flange along the bottom and bolting (2) 1 3/4" x 11 1/4" LVL's to each side. The total depth of the WT 12 x 31 is 11 7/8" to match the joists and the flange is 7" wide which is wide enough to bear on top of the wall top plates without crushing the wood. The weight of this steel member is only 31 plf, obviously lighter and cheaper than the previously discussed plates. It seems like a great practical solution but I've never seen WT shapes used in flitch beams before and I can't find anything on the Google machine. Anyone have any insight?
