Awais Arshad
I am in a fix these days while designing a modified U-tube bundle for a heat exchanger on ASME VIII-I and TEMA ‘R’. Originally, exchanger had a 13 Cr-Mo 44 metal grooved gasket. Now while I am modifying the tube-bundle due to updated process requirements, I need to evaluate the exchanger for:
1. Existing Girth flange
2. New Required tube-sheet thickness
For Girth Flange evaluation, I need m & Y factors for gasket. In ASME Section VIII Div.1 Table 2-5.1 (Mandatory Appendix-2), I am unable to find m & Y factors for 13Cr-Mo44 material metal grooved gasket. Since existing gasket material is 13 Cr-Mo 44, what value for m and Y should I use?
Awais
Awais
