Typically my relief valve set pressure is set at my MAWP, but I have a case where my set pressure is below MAWP because of a small, but constant back pressure.
If my vessel is rated for 45 psig, but my set pressure is 42.5 psig, what is my MAAP for a fire scenario? If I'm telling a relief valve vendor my set pressure and using 21% overpressure for fire, I would expect my MAAP would be limited by the valve at 51.4 psig. Thoughts?
