Macro for creating CATproduct from CATpart which contains multilayered geosets
ARSRoy
Automotive
Jan 3, 2021
3
IN
Hi all,
I'm trying to create a macro which converts a CATpart containing multilayered geosets into a CATproduct. I have attached a screenshot which shows, how the product needs to look when converted from Catpart. Also, I found a macro on this forum which creates CATproduct from a CATpart containing bodies. I tweaked it to work with geosets. But, I couldn't make it work for multilayered geosets.
Below code is written by user LINGSHUYING. I tweaked it to work for geosets instead of bodies.
Code:
Sub GreateProductsFromBodies_SelectAllBodies()
    'Purpose : Create  Product's  from Part's Bodies
    'add Error control and connect to CATIA application
    On Error Resume Next
    Set CATIA = GetObject(, "CATIA.Application")
    'Declare variables
    Dim oPartDoc As PartDocument
    Dim oPart As Part
    Dim oProductDoc As ProductDocument
    Dim oProduct As Product
    'Create a new ProductDoc and rename it's PartNumber equals to Partdoc's PartNumber
    Set oPartDoc = CATIA.ActiveDocument
    Set oProductDoc = CATIA.Documents.Add("Product")
    oProductDoc.Product.PartNumber = oPartDoc.Product.PartNumber
    'Arrange windows use "Title Vertically" ,then active window contain Partdoc
    CATIA.Windows.Arrange catArrangeTiledVertical
    CATIA.Windows.Item(1).Activate
    'Check the Body's name use "For ... Next"loop . If Body's name duplicate,then rename.
    Dim k As Integer, x As Integer
    For x = 1 To oPartDoc.Part.HybridBodies.Count
        For k = 1 To oPartDoc.Part.HybridBodies.Count
            If oPartDoc.Part.HybridBodies.Item(k).name = oPartDoc.Part.HybridBodies.Item(x).name And k <> x Then
                oPartDoc.Part.HybridBodies.Item(k).name = oPartDoc.Part.HybridBodies.Item(x).name & "_Rename_" & k
            End If
        Next
    Next
    'Copy Bodies from PartDocument
    Dim i As Integer, j As Integer, ProductPN As String, FinalProductPN As String
    For i = 1 To oPartDoc.Part.HybridBodies.Count
        With oPartDoc.Selection
            .Clear
            .Add oPartDoc.Part.HybridBodies.Item(i)
            .Copy
            .Clear
        End With
        'Modify the Product's PartNumber,replace "\" and "."to "_" ,then delete Space
        ProductPN = oPartDoc.Part.HybridBodies.Item(i).name
        If Right(ProductPN, 1) = "\" Then
            ProductPN = Left(ProductPN, Len(ProductPN) - 1)
        End If
        FinalProductPN = Replace(Replace(Replace(ProductPN, "\", "_"), ".", "_"), " ", "") 'Replace "\" and "."to "_",Delete Space
          'Paste Body in Product's Part as Result
        Set oProduct = oProductDoc.Product.Products.AddNewComponent("Part", FinalProductPN) 'Add Part
        With oProductDoc.Selection
            .Clear
            .Add oProductDoc.Product.Products.Item(i).ReferenceProduct.Parent.Part
            .PasteSpecial "CATPrtResultWithOutLink"
            .Clear
        End With
        oProductDoc.Product.Products.Item(i).ReferenceProduct.Parent.Part.Update
    Next
End Sub
 https://files.engineering.com/getfile.aspx?folder=cc21b548-eb69-420a-9e61-441bd5f21be4&file=CATpart_to_CATptoduct.png
your multilayerd geosets, will they contain a mix of features and geosets?...
if not, you need to see if there are geosets under, or just geometries and act accordingly
regards,
LWolf
Hello LWolf,
Thanks for your reply. No, it only contains geosets which eventually contains geometric elements and hybrid shapes.
From your sentence , I can only think of If statements. Please see below. I'm not sure how to call the Hybrid shapes or Geomteric elements.
Code:
         If oPartDoc.Part.HybridBodies.Item(i) = oPartDoc.Part.HybridBodies.HybridBody Then
                Set oProduct = oProductDoc.Product.Products.AddNewComponent("Product", FinalProductPN) 'Add Product
         'FinalProductPN will be defined
          ElseIf oPartDoc.Part.HybridBodies.Item(i) = oPartDoc.Part.HybridBodies.HybridBody.HybridShapes Then
               Set oProduct = oProductDoc.Product.Products.AddNewComponent("Part", FinalProductPN) 'Add part
         Endif
try to create a recursive function, i.e for each hybridbody encountered, check whether there is/are any other hybridbodies within...
if yes then call on the function again with the new hybridbody, else create a part from that set.
so, when you are investigating a hybridbody, it has properties Hybridbody.hybridbodies.count
regards,
LWolf
This could really balloon into a lot of products being created. I really question why you would want/need this functionality.
