Macro not running
koubaleite
Hello, this is my first time encountering this. I have double checked and all my variables just work fine and have the right values.
I did recently an update of SolidWorks and from what I read online I have to update references (already did).
Does anyone able to run this code on their computer ?
Do you know why it is not running on mine ?
Thanks in advance
Code:
Sub TraverseAndRenameComponents(swModel As SldWorks.ModelDoc2, Codice As String, ByRef Position As Long)
    Dim swConfMgr As SldWorks.ConfigurationManager
    Dim swConf As SldWorks.Configuration
    Dim swRootComp As SldWorks.Component2
    Dim vChildComp As Variant
    Dim i As Long
    Dim swChildComp As SldWorks.Component2
    Dim swChildModel As SldWorks.ModelDoc2
    ' Get Configuration Manager and Active Configuration
    Set swConfMgr = swModel.ConfigurationManager
    Set swConf = swConfMgr.ActiveConfiguration
    Set swRootComp = swConf.GetRootComponent3(True)
    ' Check if the root component is valid
    If swRootComp Is Nothing Then
        MsgBox "No components found in the assembly."
        Exit Sub
    End If
    ' Traverse child components
    vChildComp = swRootComp.GetChildren
    For i = 0 To UBound(vChildComp)
        Set swChildComp = vChildComp(i)
        If Not swChildComp Is Nothing Then
            Set swChildModel = swChildComp.GetModelDoc2
            If Not swChildModel Is Nothing Then
                If swChildModel.GetType = swDocASSEMBLY Then
                    ' Recursively traverse subassemblies
                    TraverseAndRenameComponents swChildModel, Codice, Position
                ElseIf swChildModel.GetType = swDocPART Then
                    Dim OldName As String
                    Dim NewName As String
                    ' Use component name as description for naming
                    OldName = swChildComp.Name2
                    NewName = Codice & "_" & Position & "_" & OldName
                    ' Rename component and increment position
                    Debug.Print "Old name: " & OldName
                    Debug.Print "New name: " & NewName
                    swChildComp.Name2 = NewName
                    Position = Position + 1
                End If
            End If
        End If
    Next i
End Sub
Sub Main()
    Dim swApp As SldWorks.SldWorks
    Dim swModel As SldWorks.ModelDoc2
    Dim Codice As String
    Dim Position As Long
    ' Create the SolidWorks application object
    Set swApp = Application.SldWorks
    ' Set the active document
    Set swModel = swApp.ActiveDoc
    ' Check if there's an active document
    If swModel Is Nothing Then
        MsgBox "No active document found."
        Exit Sub
    End If
    ' Ensure the active document is an assembly
    If swModel.GetType <> swDocASSEMBLY Then
        MsgBox "The active document is not an assembly."
        Exit Sub
    End If
    ' Get user input for Codice (fixed prefix) and Position (starting number)
    Codice = InputBox("Enter Codice (fixed prefix):")
    Position = CLng(InputBox("Enter starting Position number:"))
    ' Traverse and rename components
    TraverseAndRenameComponents swModel, Codice, Position
End Sub
