  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Macro to insert catalog part
TiagoFigueiredo
Industrial
May 22, 2013
494
0
0
PT
I, I have created some PKT templates, and stored them in a catalog.
Now I want to add those PKT templates by using macros, and automate a few things, Like the inputs, save with the desired Part Number...
I have made a few searches, but didn't found anything relevant. But is it possíble to to add this products or parts stored in catalogs, by using macro?
Tiago Figueiredo
Tooling Engineer
Youtube channel:
in "C:\Program Files\Dassault Systemes\B30\win_b64\code\bin\V5Automation.chm" search for "instantiate user feature"
regards,
LWolf
MKEdits said:
Hello, have u tried recording your operations and "globalize" them?
You mean, record macro? Yes I did, but the results of recording, didn't worked...
That's for user features and power copies, or there is something that i'm not seeing. I need for template insertion.
Tiago Figueiredo
Tooling Engineer
Youtube channel:
If there is no commands as a result of recording - those functions has no API, if there was something but only "didnt work"- you can paste lines of earned code here and we will solve it.
M
I,
I have made the recording and here it's the result:
Code:
Sub CATMain()
Dim documents1 As Documents
Set documents1 = CATIA.Documents
Dim productDocument1 As ProductDocument
Set productDocument1 = documents1.Item("conj.CATProduct")
Dim product1 As Product
Set product1 = productDocument1.Product
Dim products1 As Products
Set products1 = product1.Products
Dim product2 As Product
Set product2 = products1.Item("0001.1")
product1.PartNumber = "conj1"
Dim partDocument1 As PartDocument
Set partDocument1 = documents1.Item("CATPart4.CATPart")
Dim product3 As Product
Set product3 = partDocument1.GetItem("0001")
product3.PartNumber = "00011"
Dim partDocument2 As PartDocument
Set partDocument2 = documents1.Item("CATPart6.CATPart")
Dim product4 As Product
Set product4 = partDocument2.GetItem("0002")
product4.PartNumber = "00021"
Dim productDocument2 As ProductDocument
Set productDocument2 = CATIA.ActiveDocument
Dim product5 As Product
Set product5 = productDocument2.Product
Set product5 = product5.ReferenceProduct
End Sub
Just to make sure, that we are all talking about the same thing. This is similar to what I want to automate, but instead of having CATIA interface, having a macro, to automate a few other things, like rename the component.
Tiago Figueiredo
Tooling Engineer
Youtube channel:
I really like AutoIT better than native macros. Much more understandable and much more flexible. If you can do it with a keyboard and a mouse then you can do so with AutoIT.
