Macro to position CATPart and its instances at specific coordinates
pravs
34
I am trying to create a macro to automate the positioning of desired Catpart in a product onto a desired coordinates . I know the coordinates . I tried to record a macro by using 'snap' command but the code generated was not suitable. Please help me out.
Thanks in advance
Do you insert a new file or is already existing in the product? Are you working in a database (for example VPM)? Are you working with files on a network?
These are just some questions which you need to clarify if you want to point a developer in the right way...or your searches...
If you will search the forum with keyword insert you will find also some relevant posts.
Fernando
How i see this , the catpart should have related his driving geometry to a point inside with coordinates acording to absolute axis . When inserting the part, macro should read this point and change coordinates to new imput values .Is this what you want ?
Tudor
The part is already inserted and is at some random position . The part and its corresponding instances have to get positioned automatically to a specific set of points( I have a macro to get coordinates of these points).
Hi.
Use this snippet:
Code:
Dim pos(11)
partInstance.Position.GetComponents pos
pos(9) = newX
pos(10) = newY
pos(11) = newZ
partInstance.Position.SetComponents pos
Hi Little Cthulhu,
The code is working, thank you so much . I am facing a minor error, I am trying to get coordinates of points where the part instances have to be positioned so I used the below lines of code. But the part instances are being placed at different x,y,z . I don't understand where I am going wrong.
pos(0) = coords(0)
pos(1) = coords(1)
pos(2) = coords(2)
Why on earth would you change my working code and then ask "why it doesn't work"?
Don't you think I used 9,10,11 for a reason?
Sorry That was a typo. I used 9,10,11 only . The minor error I mentioned still remains the same.
Are you moving parts inside a multi-level assembly with different coordinate systems at each level?
And [tt]SetComponents[/tt] sets position in local coordinate system. You have to do some math to calculate coordinates in global axis system.
See this thread at COE.
