Macro to rename instances
CA
I have found in a thread a macro to rename the instances with the part number in Catia V5 that seems to be exactly what i want to do but i get an error when i try to run it.
i get a message saying CATSripErrorMessages - Scripting ERR_1002
Execute the script name of my script .catvbs.
Source: Microsoft VBScript compilation error
Description'Expected end of statement
Statement :Dim Docs As Documents
Line 2
Column 9
We use Catis V5 R20 on window 10
i am not experimented with macros. Any help would be apprecated.
In vb scripts it is not allowed to use variable types declaration as all variables are variants. I think you have to launch this macro in VBA,
or maybe try to save it as .catscript where "As" clauses are just being ignored.
Other option is to uncomment or delete all "As" statements in your code and instead of
just use
Dim Docs
Tesak
Tesak
- Play Tetris in CATIA V5 drawing
Good morning Tesak,
Thank you very much for taking the time to reply. I saved the macro .catscript and it worked.
Trully appreciate your help.
Martin
