I want to model concrete beams in Abaqus explicit that doesn't support *Rebar . I also cannot use solid or shell elements due to the scale of the structure.
I chose to create 2 beam elements for each part ( a beam with a rectangular section for concrete and an I-section beam with a near-zero web to model rebar by flanges).
What do you think about this solution? How can I connect these two beams to work together and consider the composite effect in RC members?
If I use the same mesh configuration for two beams and tie all corresponding nodes, does it mean they work in parallel?
Best regards,
Ali
Best regards,
Ali
