Manhole Design approach
yosephWorkuZenebe
3
I asked ChatGpt for Manhole design approach and it said
"The design approach for a manhole depends on its depth, loading conditions, and soil characteristics. It can be treated as either a cantilever wall or a box structure,
Which Method to Use?
  • For shallow manholes (up to ~3m depth) → Cantilever Wall Design may be sufficient.
  • For deep manholes (>3m depth) → Box structure design is preferable to distribute loads more effectively.
  • For high groundwater levels → A box structure with a waterproofing system is recommended.
can some explain cantilever approach ? thanks
That's what you get for asking AI how to design something. Manholes are almost always round for a reason. It's designed as a hoop with soil pressure all around the outside. Live load surcharge is typically the only unbalanced lateral pressure. The primary loading of concern for design is the vertical load from vehicles.
Even a box-shaped manhole would be more efficiently designed with the walls spanning horizontally.
In any case, the design for vertical live load (truck wheel loads) is typically the area of most concern in design.
And so it begins - engineers using AI to design something.
I may move to the high mountains far from structures.
I asked ChatGPT about "bristol centaurus engines". It got the number cylinders right. It got the displacement wrong. It listed three aircraft in which it was used, one of which actually did use it. It did not mention the sleeve valves it used.
Should ChatGPT have anything whatsoever to do with engineering design? No!
