johnthebest
- Mar 7, 2018
- 57
We are on the go of a central processing facility project.
our contractor claims that in order to match the CV of the conrol valves (as per ASME B16.34) and the manual globe valves (as per API 623) (which serves as a by-pass of the control valves and will be operated only in case of maintenance of the control valve), both valves shall be procured from the same vendor.
the control valves are already procured. however, when they want to procure the manual valves from the same vendor, they came with these deviations (see attached file).
Is it true that in order to get the same CV you have to buy manual and control valves from the same vendor? if yes, what are your thoughts about the deviations.
Thx in advanve
Thx in advanve
