Hi all,
I'm simulating a hot rolling processes. So far I have simulated a single pass but I now want to model a second pass.
To do this I imported the deformed slab from my first odb as a part in my model for the second pass, I repositioned my
roll for the second pass and then I also want to import the temperature field of the deformed slab into my new model. This is were I am having problems. I tried to use an analytical field to map the NT11 field variabel of my first odb to my new model, but this isn't working. When running the job I get a warning that 'The mapper may have not mapped to all expected entities.
The default field value will be used for missed entities.' When then looking at the results I see that none of my values
have been mapped.
Obd with the values that have to be mapped:
Model to where the values have to be mapped:
have been mapped.
