I've got a couple questions regarding the overall statics involved. I've seen this discussion for wood shear walls, but I'm not really sure how to approach for CMU.
I've got a masonry shear wall that will attach to a concrete transfer beam. The shear wall portion of the wall is partial to the overall length of the transfer beam, so I'm trying to determine how to most appropriately load the beam.
The question comes down to how to distribute the flexural couple, and the axial loads along the wall length. I know the traditional approach, for the design of the wall, is to disregard the contribution of the field vertical steel and dump all the tension forces into the wall's tension chord.
•Assuming flexure is the only heavy load, there would be a compression zone that would balanced with flexural tension: 0.80f'm(a)(b) = Asfy
•When considering axial & flexure, 0.8f'm(a)(b)=P + Asfy
Note: In the paragraph above, this simplification greatly underestimates the flexural capacity of the wall. I understand that a trial and error procedure for the correct neutral axis and the interaction diagram can be used to find the balanced condition moment capacity. I've only ever seen this as an academic exercise, rarely do I have a budget to go down this path.
All that being said, these are procedures for the design of the wall. My question is, what does the transfer beam feel? IMO, gravity loads would always be uniformly distributed along the length of the wall, and they should not affect the depth of the flexural compression zone by way the equation 0.8f'm(a)(b)=P +Asfy.
I'm tempted to design the beam for 4 distinct parts in combination.
1) gravity loads (applied about beam's strong flexural axis)
2) force couple point loads; Simply M/d (applied about beam's strong flexural axis)
3) shear wall's "base shear" into the beam as an axial load
4) lateral wind load from side wall suction (applied about the beam's weak flexural axis).
Thoughts?
Thoughts?
