cpdonahue
- Aug 6, 2011
- 13
I have a small project masonry project for which 1 set of 3 mortar cubes were made and tested for compressive strength. Low 28-day strengths were 600 psi for Type S. There is only 1 set due to size of project and contractor not calling for testing. Can the prism method by done (ASTM C 1314) by cutting out some prisms (non-grouted masonry) from the existing walls and testing for Prism Test?
Are there other options to verify in-place mortar strength? I know generally speaking, mortar cubes are to act more as an indicator of the trend of the strengths, and not actual in-place strength.
