AleksaBgd94
Hi everyone,
which value of mass density should I adopt for steel material?
Everything in my model is defined in mm and N.
I assume that mass density should be in N/mm3 because everything is defined in N and mm, so I calculated the value for mass density of 76.982e-6 N/mm3.
Is there a mistake here?
