Mass Source in Etabs
maniafridi
When I calculate the weight of the building for a combination D.L +0.5 L.L similar to that Mass source defined then why the vertical reaction Fz is Greater than the Seismic Weight used for Base Shear Calculation
See the Image Below
It's because the bottom half of the lowest level is not considered in the seismic mass. But it is considered in the same constructed load case.
Thank u for your answer and I confirmed it manually you are 100% right.
