How do I specify the material or density of a solid so that when I get mass prop. I have an actual mass. Right now I get the same mass as I do volume b/c it defaults to a density of 1, I asssume. Where can I change this?
Yes- This is a long recognized shortcoming. All I am aware of is to multiply the mass value X the weight / CU-IN of your material. Silly isn't it?
Good luck.
