structeng2
- Apr 18, 2016
- 38
I have a question on how to check/verify typical foundation requirements (overturning, bearing pressure, etc.) when I have a steel column mounted on a pilaster part of a continuous wall.
I guess I am not sure how you would figure out what your 'footing' dimensions are to determine eccentricity, toe/heel pressure, and run through the rest of a typical spread footing calc. Or is there another method I should be using? It almost acts more like a continuous wall footing with a concentrated point load at the column location - however, the same question still stands, how to determine your footing dimensions if your 'footing' (mat slab) is continuous.
Peter
Peter
