MATERIAL BOLT FOUNDATION
jim81276
31
HELLO FRIENDS
Currently I have a shredder equipment that I have to install but I do not know what material the foundation bolts are that you should carry and neither is your material.
I only have the dimensions of the foundation bolts M48X1000 and their quantities 6 set.
I hope your help soon ...
Thank you
Sizing bolts like that would depend on the equipment characteristics and on the foundation details that the bolts go in. You need to contact whoever sized the bolts to see what kind of bolt they were assuming- bolt size will vary depending on the grade used, for example.
