TomaszKruk
hello,
I have a question about resources evaluating piping material compatibility for oxygen service. We are using EIGA documents, but they recommend Inconel / Monel / Hastelloy for pressures above 4,0 MPa. And that's it. I was hoping to find some data regarding possibility of using stainless steel instead, since this is what is working on the plant right now. Wall thickness adjusted, ofc.
I cannot go into details, but it's oxygen pressured to around 40 bar, gas velocity around 12 m/s, temperature 150oC.
Can you recommend where to look? Any thoughts regarding material selection? Nickel alloys are recommended - should I not trust my lying eyes that see stainless there?
