Using SW 2020 and I have a part with 3 configurations in it. Each configuration uses a different material. In the Custom Properties, I have a Property called Material defined. For the value, I can specify the material option and the function "SW-Material@...." is placed. However, when I Save the part, this function disappears and the Value becomes text of the material. Due to this, when in the drawing, the material note does not update per the displayed configuration.
Any ideas
Any ideas
