sathish kumar dhanasekaran
Petroleum
DEAR SIR
I AM WORKING FOR A PETROLIUM REFINARY PROJECT .. MOST OF THE VARIOUS TYPES OF MATERIAL USED IN PIPING ACTIVITIES FOR VARIOUS TYPES OF SERVICES .. MY QUESTION IS HOW TO SELECT A MATERIAL TO SERVICES BASED (IF EXAMPLE DE MINERALISED WATER SERVICE LINE IS MADE FOR STAINLESS STEEL ) HOW TO THEY ARE SELECT THE MATERIALS .WHICH SECTION IS REFERRED TO SELECT .. WHAT ARE THE IMPORTANT FACTOR CONSIDER FOR SELECT A PIPES TO SERVICE BASED APPLICATIONS .. MY ANOTHER DOUBT IS DM WATER LINE IS NOT A DRINKING WATER LINE THEN ALL MINERALS ARE REMOVER SO NO HAVE AN OXYGEN IN THIS WATER SO I THINK IN THIS WATER IS NOT REACT WITH MATERIAL NOT MAKE A CORROSION MAKE A CORROSION ..SO WE ARE USED FOR LOW ALLOY STEEL IS PREFFERED FOR THIS APPLICATION SERVICES ECONOMY WISE IS A GOOD .COMPARE THEN STAINLESS STEEL COST... WE ARE COMPARE FOR LIFE OF STEEL SS IS BETTER THAN ALLOY ..I HOPE TO WAIT FOR A PROPER ANSWER TO YOU
THANKING YOU
THANKING YOU
