Material to outlive the Giza Pyramids 3
Stephen.Scott
4
0
0
Would 316 be the best material for fabricating long-life sculptures?
I want to make artwork ("modern Rosetta Stones") that can survive thousands of years.
Would electroplating, xylan coating, or some other coating be required for locations other than desert environments?
A platinum-iridium allow was chosen for the kilogram standard.
Stainless steel and other materials that require passivation are too finicky. A nickel alloy would likely be best.
Don't make it too valuable, someone will find it and melt it down.
Stone isn't a bad material for a sculpture...
Gold lasts a long time?
Titanium?
Thanks for the feedback. I've worked regularly with 40HRC 718 inconel. What coating would protect it the most from the elements?
Looking at the past, stone may be the best material to work with if the sculptures can remain in a desert. Maybe granite or basalt.
Would titanium work better than something nickel-based?
The main loss of sculpture is by theft. Making it of any metal is just expanding the potential range of thieves.
To get something to last a long time, start a religion of worship for it, but choose the fanatics carefully.
Bronze is one of the substances that will last the longeste exposed to the elements. I dont know if there is a special "sculpture" mix but you might be able to find out yourselve.
--- Best regards, Morten Andersen
