hamidun
- Jun 3, 2014
- 80
Dear All,
I have read in this forum that if We have a WPS with same P-NO. material but different Gr. No., We can use the same WPS for that different Gr. No. material when the different Gr. No. material does not have impact property requirements.
My question is how to know whether a material is required to have impact property or not. Because I could not find a material with impact property requirements.
Or do we decide whether a material is required to have impact property or not by knowing the maximum operation temperature of the material used? For example, if the operating temperature exceeds the capability of the material (in this case at low temperature), we need to do impact test for the material, so that we know impact property for that material and after that we need to make a new WPS for that material.
Please help, thank you.
