This question is sort of motor related (X Axis servo ramping profile) but I put it here because I hang out here a lot and there are a bunch of calculus "Geeks" who hang out here.
We have a lens polisher that spins a lens slowly and a fast spinning polishing ball is loaded against the lens. The spinning ball traverses the lens radially starting at the lens circumference with a velocity (Vs) at the circumference. The velocity then ramps up by the formula
Vc = Vs x Rs/[Rs-x]
Rs = radius of the Lens
x = negative radial position
The velocity is a hyperbola which would have an infinity value at x = Rs but we terminate the velocity to some Vmax at some radial position.
The PLC programmer has a "Brute Force" method of calculating the time to Vmax but asked if the is an elegant solution to the question of Time to Current Position or Time to Vmax).
The equation is in terms of velocity vs. position and I believe there is probably a closed form solution (there may not be) but being 45 years away from Calculus 4, I'm a little rusty. Some of the folks here are more Current and have less gray hair.
Vc = Vs x Rs/[Rs-x]
