jochav52802
- Nov 28, 2018
- 81
Good Evening,
I'm studying for the Structural portion of the California PE Exam, and one of the problems asks me to determine the question posed in the title of this post.
In their solution, they take the diaphragm force and evenly distribute it to each of the walls that are parallel to the seismic force, however, they then proceed to add the diaphragrm's seismic force to only half of the parallel wall's seismic selfweight to come up with the maximum force in the parallel walls.
My questions is whether this is correct, as intuition would tell me that I should add the parallel wall's full seismic force to the diaphragm force in order to determine the maximum shear wall force. I understand that it's standard practice to assume that half of the perpendicular wall seismic load is distributed up to the diaphragm, but I nor my colleagues are following why a similar approach would be used for the parallel walls since they're the lateral-load-resisting-system that carry the main building loads to the foundations.
I'd appreciate any support in understanding why my thinking may be off.
Many thanks in advance!
Best regards,
jochav5280
Best regards,
jochav5280
