I am fabricating heat Exhanger through one of local contractor. As per drawing specification the thickness of Tube sheet is 30mm . However the available plate for tube sheet have thickness of 63mm. Please confirm that is it allowable to reduce thickness by 33mm through machining. Does this thickness reduction will effect on material integrity. Also please confirm through relevant ASME or TEMA standard that allows or quote any clause related to thickness reduction through machining.
Plate material: Carbon Steel
Wasif
Wasif
