Hi! I am designing a roof with a significant CLT cantilever on one end. The deflection equations in the code are set up for a simple span beam. Does anyone have any guidance on maximum cantilever for a CLT panel, or for an approach to calculating the cantilever deflections (id expect that shear deformation would be much higher than for the simple span)
Thanks so much!
Thanks so much!
