ShawThing
- Aug 17, 2017
- 46
Is there a maximum length that diagonal rod bracing may be used for lateral roof trusses after which you revert to an angle section?
My understanding is that pretension will negate most of the sag or alternatively they could be supported via the roof purlins.
I have diagonal members that will be up to 10m to 11m long and was wondering if that is too much for rods even through the tension capacity is fine.
