rudiawan .
Petroleum
i do the pipe stress analysis for piping connecting to the api 650 tank.
refer to annex P on the API 650, The limiting piping loads are as follows: FR, MC & ML
FR max is the radial thrust applied at the mid-surface of the tank shell at the opening connection, in N (lbf);
MC Max is the circumferential moment applied to the mid-surface of the tank shell, in N-mm (in.-lbf);
ML Max is the longitudinal moment applied to the mid-surface of the tank shell, in N-mm (in.-lbf);
How to convert into FX,Fy,FZ, Mx,My and Mz, so can easily compare with the result of load in the nozzle from piping stress analysis software
