MCT (multi cable transit) on Roof top
Histor
70
Can I use MCT on a concrete rooftop? if yes, can I use 4 bar water-resistive Roxtec SK frame MCT?
I used MCT in order to ensure a fire stop on a wall opening [horizontal way].For vertical installation the total weight is important to check not to be more than the resistance limit [usually 1000 kgf/square m], I think.
