Hello to everyone.
I am using NX12. Sometimes I use assembly explode to simulate some simple kinematics. Sometimes it would be verry handy if I could measure some dimensions after the explosion was done.
But it seams that you can not measure in exploded state. The measure will work but it will measure dimensions as if there is no explosion. For now I find out a workaround with extrtact curve. I am extracting curves that I need and use them to measure. But beacuese it is a legacy feature I guess it will be soon removed from NX.
Is there any other way to do it?
Thanks in advance.
Best regards
Thanks in advance.
Best regards
