Jon9
- May 4, 2019
- 7
I am having some issues measuring the flow velocity and pressure in a 100mm pipe that is a couple of meters long. The issue that I have is that the pressure and velocity are very low at 1.5 bar and 1ms^-1 respectively and I could certainly use some help here. I have few holes drilled onto the pipe and I was thinking of sticking a pitot tube in there and use a manometer as well but I am not sure if that actually works in practice? or if there is perhaps a more sensible way of measure the flow velocity given how low it is? would an ultrasonic flow meter be better? I should probably mention that the pipe is 1m underwater.
I am curious if anyone here has any ideas of how to approach this problem?
