question about the function of Throttle bush in Single Seal plan 32 :
1)does it prevent leak or to reduce the leak?
2) standard clearance between throttle bush & sleeve?
3) as you can see in the attached picture PIT Port is not used on the seal just plug, how that will be use to help & prevent the leak?
