MENU 1
spottydot
Aerospace
Apr 21, 2004
36
IS THERE A WAY TO CHANGE THE MB3 MENU.
Yes, there is a way to change the mb3 options.
I've done this before a year and I can tell you there is enough information in the help files. The menu file is located in <install dir>\UGII\menus and the file's name is ug_view_popup.men. You can open it with any text editor you like. For the syntax please review the documentation.
I hope this helped.
_____________________________________
"...standards are great because they give nonconformists something to not conform to..."
_________________
Penkov, Peter I.
Non-standard Equipment Designer
This was an excellent info. There are "bmp" file names in this file. Do you know where those bitmap files are located ?.
The 'out of the box' bitmaps are hard-coded into the software & you cannot access them directly. However, you can copy them using screen capture/print screen & then paste them into an image editing or icon making software.
Tim Flater
Senior Designer
Enkei America, Inc.
