Merry xmas and a peaceful 2004...
Lothar
;;AUTOCAD PROGRAMMING CHALLENGE NO. 2
;;C:XMASTREE
;;John F. Uhden, CADvantage Custom Utilities
;;CADvantage@compuserve.com
;;12-11-97
;;Note (12-08-02):
;; Jim Fisher recalls better than I the rules of this
;; programming challenge on the old ACAD Forum.
;; Technically, this exceeded limitations and should
;; have been disqualified. Dietmar Rudolph's was
;; technically correct and pretty darn nifty. Too
;; bad I don't have a copy to share. In fact, we can
;; thank Jim for retrieving this from his archives.
;; Anyway, it's still cute.
;;Revised (12-08-02) for R15+
;; Added vl-cmdf, UCSICON=0, and SHADE command only.
;; Try setting SHADEMODE to different values before running,
;; and then use the 3DORBIT command after.
;; HAPPY HOLIDAYS!
(defun c:XMASTREE (/ rad R N Z dZ a da d H I J K +- s c)
(setq c (if (>= (getvar "acadver"
"15"
vl-cmdf
command
(setq d distance
s setvar
(s "CMDECHO" 0)
(s "UCSICON" 0)
(s "TILEMODE" 1)
(s "UCSFOLLOW" 0)
(s "HIGHLIGHT" 0)
(s "REGENMODE" 1)
(c "_.LINE" "0,0" "1,1" ""
(c "_.ZOOM" "_E"
(C "_.LAYER" "_U" "*" ""
(C "_.ERASE" (ssget "X"
(c "_.UCS" "_W"
(C "_.VPOINT" "-3,-3,1.2"
(C "_.ZOOM" "_C" "0,0,7" 15)
(defun rad (Z) (* 0.75 (sqrt (- 12.0 Z))))
(setq N 25
Z 1.0
dZ 0.5
a 0.0
da (/ pi N)
hpi (* pi 0.5)
(while (< Z 12.0)
(setq R (rad Z))
(repeat N
(setq +- (if (= +- -)
H (list 0.0 0.0 (+- Z (* dz 0.25)))
I (polar H a R)
a (+ a da)
I (mapcar '+ I (list 0.0 0.0 (* dZ 0.5)))
J (polar H a (+ R R))
a (+ a da)
J (mapcar '+ J (list 0.0 0.0 dZ))
K (polar H a R)
K (mapcar '+ K (list 0.0 0.0 (* dZ 0.1)))
(entmake (list '(0 . "3DFACE"
'(62 . 3)
'(70 . 0)
(cons 10 H)
(cons 11 I)
(cons 12 J)
(cons 13 K)
(if (and (zerop (rem (1- Z) 1)) (zerop (rem N 5)))
(progn
(entmake (list '(0 . "CIRCLE"
(cons 10 J)
'(40 . 0.07)
'(39 . 0.35)
'(62 . 255)
(prompt " HO"
(setq J (mapcar '+ J (list 0.0 0.0 0.4)))
(entmake
'(62 . 2)
'(70 . 0)
(cons 10 (polar J (+ a hpi) (* (d I K) 0.2)))
(cons 11 (polar J (- a hpi) (* (d I K) 0.2)))
(cons 12 (mapcar '+ J (list 0.0 0.0 (* dZ 0.5))))
(cons 13 (mapcar '+ J (list 0.0 0.0 (* dZ 0.5))))
(terpri)
(setq Z (+ Z dZ)
a (+ a (/ da 2))
(entmake '((0 . "3DFACE"
(62 . 7)
(10 -0.536 0.57073 13.225)
(11 0.5123 -0.545566 13.225)
(12 -0.011815 0.012582 12.6687)
(13 -0.0118153 0.012582 12.6687)
(70 . 0)
(62 . 7)
(10 -0.3357 0.3575 12.325)
(11 -0.0118 0.01258 13.7813)
(12 0.18839 -0.200611 12.8812)
(13 0.188387 -0.200611 12.8812)
(70 . 0)
(62 . 7)
(11 0.31212 -0.33237 12.3249)
(12 0.111916 -0.11918 13.225)
(13 0.111916 -0.119179 13.225)
(70 . 0)
(c "_.SHADE"
(setvar "cmdecho" 1)
(alert "\nMerry Christmas!"
(princ)
Lothar
;;C:XMASTREE
;;12-11-97
;;Note (12-08-02):
;; HAPPY HOLIDAYS!
vl-cmdf
command
(setq d distance
s setvar
(s "CMDECHO" 0)
(s "UCSICON" 0)
(s "TILEMODE" 1)
(s "UCSFOLLOW" 0)
(s "HIGHLIGHT" 0)
(s "REGENMODE" 1)
(c "_.ZOOM" "_E"
(c "_.UCS" "_W"
(setq N 25
Z 1.0
dZ 0.5
a 0.0
da (/ pi N)
hpi (* pi 0.5)
(while (< Z 12.0)
(setq R (rad Z))
(repeat N
I (polar H a R)
a (+ a da)
a (+ a da)
K (polar H a R)
'(62 . 3)
'(70 . 0)
(cons 10 H)
(cons 11 I)
(cons 12 J)
(cons 13 K)
(progn
(cons 10 J)
'(40 . 0.07)
'(39 . 0.35)
'(62 . 255)
(prompt " HO"
(entmake
'(62 . 2)
'(70 . 0)
(terpri)
(setq Z (+ Z dZ)
a (+ a (/ da 2))
(62 . 7)
(70 . 0)
(62 . 7)
(70 . 0)
(62 . 7)
(70 . 0)
(c "_.SHADE"
(princ)
