Dear all
I am reviewing an elastic stress analysis of legs to shell junction for protection against plastic collapse. The vendor wants to show that the stress results for the analysis are free from mesh size. First he has reduced the mesh size from 100 mm to 50 mm and the maximum stress has increased from 88 MPa to 101 MPa. Then he has reduced the mesh size to 40 mm and the stress increased to 115 MPa. He then has concluded that the stresses are stabilized with respect to the mesh size and the results with this mesh size are reliable. I cannot accept it since he has decreased the mesh size by 20% while increasing the stress by 15%. This does not look like any stability in results. However, I do not have any reference or criteria to tell me what is the reliable answer with respect to the mesh size. Is it 3%? Is it 5%? And this with respect to how much reduction in mesh size?
On the whole, I want to know if there is a remedy to meet this problem. Should I simply shift to elastic plastic method? I have had this problem especially when working with shell elements. Do you think using solid elements would help? And finally I was curious if there were problems using shell elements in elastic-plastic models.
Thanks in advance
Thanks in advance
