Meshing
nmknop
Aerospace
Jun 26, 2008
7
I am trying to mesh a fireplace that I am modeling and have been having some troubles meshing. Most components are very thin bodies (thickness around .02-.03") and they are giving me shape violations on practically every element. Also the number of elements is going through the roof and I am exceeding the maximum allowable nodes with about half of my model meshed. Right now I am using Solid87 and have flirted with the idea of trying to use a shell element but that would mean starting over about 3 months of work. Any thoughts? I've messed around a lot with setting line lengths on my elements and also I've been setting all thickness lines (.021-.03") to have only 1 element. This is the only way that I can get it to mesh at all.
p.s. thickness is about .05% my longest length worst case but I can't really do a whole lot about that.
I can't imagine why it would take 3 months to mesh a fireplace. Why are shape issues just rearing their heads now?
Anyway, shells are your best bet. You may want to consider simplifying your geometry as well.
If you have bending dominant problems, 1 element through the thickness with SOLID87's could result in incorrect answers. 3 months is a long time to mesh a model. You should use shell elements.
