1
- #1
Hi All
I have 7 parts (independent) which are assembled together. After running the simulation i am trying to extract the nodal data from the model. Everything seems fine but what i have noticed are the node numbers. That is for every part, the node number starts from zero in the data. What I want is continuous numbering i.e. if part1 nodes are from 0-250 then part2 nodes should start from 251-300, part3 301-400 onwards. Is this possible to do? Is there anything to do while meshing?
Any answers will be highly appreciated
