knauf
- Jan 24, 2019
- 3
Suppose I have a stainless steel rod (D = 1/8 inch) and stainless steel tube (D = 1/4 inch), and I need to bend them. The catch is: I need to bend everything with the rod inserted inside the tube. When the bend is done, there has to be a clearance between a rod and the tube. If anyone has a suggestion, please do share. I know for sure that this kind of procedure can be done. And as far as my understanding goes, there should be used some kind of insert to work as an interface between a rod and a tube during the bending process. Most likely made from plastic. Or am I wrong?!
Best Regards,
Anton
Best Regards,
Anton
