Anant64
Marine/Ocean
- Dec 3, 2016
- 1
Dear all,
We have pneumatic actuated metal seated - Starline ball valve with Rotork CP actuator. 4 inch, reduced bore- 900# rating with CP - 250 actuator. The valve while opening & closing is noisy- juddering sound. Actuator is separately tested & works smoothly. Valve tested without controls - results are noisy operation. When we apply oil on the Ball sides the noise subsides & it works smoothly & again becomes noisy after few open close cycles. Air pressure min 5 bar & max 8.5 bar & noise remains.
Does this mean due to lubrication valve is making noise & is juddering. Or there is something else at play. Appreciate if any one have faced similar problem & have solution.
Download link of videos attached - we transfer.
Anant
Anant
