Metric thread geometry and tolerancing
ask34
SI
I am working on a project that requires thread milling so I have to master thread geometry. There is one thing that is unclear to me, let me explain it on an example.
I am going to thread mill M1.6 6H internal thread.
According to this website these are a few of my thread's characteristics:
Class: 6H
Pitch: 0.35 mm
Min. minor diameter: 1.221 mm
Max. minor diameter: 1.321 mm
Min. major diameter: 1.6 mm
Max. major diameter: 1.736 mm
Here is the page 206 from the book Tabellenbuch Metall:
There is an equation on this page that establishes a relation between major and minor diameter: minor = major - 1.0825 * pitch
I noticed that the equation is valid but at a certain point minor diameter will get out of it's own tolerance zone.
For example:
major = 1.736 mm (maximum alowable)
minor = major - 1.0825 * pitch = 1.736 - 1.0825 * 0.35 = 1.357 mm --> Not a valid result because max. minor diameter is 1.321 mm.
So what would be minor when major is between 1.700 and 1.736 mm?
ask34,
Those equations apply to the basic thread profile geometry, not tolerances or actual values. The allowed minor diameter does not depend on the actual major diameter.
I recommend consulting the actual specifications (such as ISO 965 or ASME B1.13M) that define the threads you are interested in.
pylfrm
