Thomas Boland
Materials
Hello! Just joined the forum.
I'd like to pick the brain of some of us that knows a lot about valves that currently exist.
I'm looking for a valve that will both act as a 1 way flow check valve, and a air release valve. Basically the application is a small fluid tank, that needs to be filled with liquid, via syringe (the Ø4mm end plastic type), such that the liquid can enter into said tank, and expel/displace the air previously in the tank, with zero leakage after the filling process is complete.
The target is to have these two functions within a small cylindrical form factor, ideally Ø7mm x 12mm or so long.
So could anyone enlighten to me as to if something similar to this description already exists, or of something that would perform the same way?
Thanks in advance!
- Thomas
Thanks in advance!
- Thomas
