Designer_82
Have these 4 dwelling units on the first floor that currently have elec. baseboard heat and no AC. Owner would like to install mini-splits. I have a couple questions I'm hoping you can help. There is a basement below. This is in the Boston area.
1. Is the mini-split the ideal choice or would you do a ducted air handler in the basement? (the cassette for the mini-split kinda ugly)
2. You can see the attached image of the unit below, where would you locate the cassettes for the mini-split for the bedroom and the living room?
3. With the mini-split you don't get any fresh air, so is that a problem not meeting the ashrae requirement?
Thank You
Thank You
